5,00 Stern(e) 53 Votes
meierchen006
Hallo @caruso56
OK, meine Software ist neuer.
anbei meine Eingaben im "CODE EDITOR" evtl. hilft dir das weiter:
Code:
type: entities
entities:
  - entity: sensor.myhome_ah56_circuit_0_state
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_current_power
  - entity: sensor.myhome_ah56_circuit_0_current_flow_temperature
  - entity: sensor.myhome_ah56_heating_energy_efficiency
    name: Tages Arbeitszahl WW & Heizen
  - entity: sensor.myhome_ah56_outdoor_temperature
    name: Outdoor Temperature
  - entity: sensor.myhome_ah56_zone_1_circuit_0_current_temperature
  - entity: sensor.myhome_ah56_zone_1_circuit_0_humidity
  - entity: sensor.myhome_ah56_circuit_0_heating_curve
  - entity: sensor.myhome_ah56_system_water_pressure
    name: System Wasserdruck
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_on_off_cycles
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_operation_time
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_consumed_electrical_energy_domestic_hot_water
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_earned_environment_energy_domestic_hot_water
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_heat_generated_domestic_hot_water
    name: Wärmeerzeugtes Brauchwasser
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_consumed_electrical_energy_heating
  - entity: >-
      sensor.myhome_ah56_device_0_arotherm_plus_earned_environment_energy_heating
  - entity: sensor.myhome_ah56_device_0_arotherm_plus_heat_generated_heating
  - entity: binary_sensor.myhome_ah56_trouble_codes
title: MyHome-AH56 / [URL_INTERNA=https://www.hausbau-forum.de/threads/vaillant-erfahrungen-arotherm-plus-vwl-35-55-75.42822/]Arotherm[/URL_INTERNA] plus 55/6
state_color: true
caruso56
Hast du mal nachgefragt ob du ein Update haben kannst von Vaillant? wegen des Fehlerhaften Integrals?
Ja, bei meinem Heizungsbauer. Bis jetzt noch keine Antwort. Der Vaillant Techniker kommt am Freitag zur Vaillant-Inbetriebnahme. Vielleicht weiß ich danach mehr. Es braucht wohl eine neue Platine. Updates per Einspielen (Kabel oder OTA) gibt es scheinbar nicht.
meierchen006
Ja so ist es, kann kaum jemand verstehen dass es so ist. Trotzdem solltest du darauf bestehen.
Übrigens mit dem ebus werde ich mich demnächst auch noch beschäftigen wollen erstmal nur auslesen von Daten, später evtl. mehr mal sehen.
Ich hätte gerne noch die Rücklauftemperatur des Heizungssystems, sofern es dafür einen Fühler/Sensor gibt.
Wann ging deine aroTherm plus in Betrieb?
meine Daten bis eben 16:30 Uhr
Zuletzt aktualisiert 16.02.2025
Im Forum Vaillant Deutschland GmbH & Co. KG gibt es 51 Themen mit insgesamt 6527 Beiträgen
1Vaillant VWL 125/6 A Luft-Wasser Wärmepumpe Erfahrungsaustausch 17
2Vaillant Luft-Wasser-Wärmepumpe - Angebot gerechtfertigt oder nicht? 18
3Wärmepumpe Vaillant aroTHERM Split VWL 125/5 AS 400V S2 + VWL 127/5 IS 21
4Kaufberatung, Vergleich Wärmepumpe: Daikin oder Vaillant? 19
5Hydraulikschema f. 2 Fußbodenheizkreis Vaillant Arotherm Tower gesucht 42
6Vaillant flexotherm exclusiv Wärmepumpe einstellen 15
7Vaillant recoVAIR Lüftungsanlage - Erfahrungen? 122
8Vaillant Kontrollierte-Wohnraumlüftung - Bericht Planer Auslegung 13
9Kontrollierte-Wohnraumlüftung & Wärmepumpe: Viessmann vs. Vaillant vs. Zehnder? 47
10Vaillant flexotherm - empfehlenswert? 26
11Wärmepumpe-Planung Reihenendhaus arothermplus 55/6 oder 75/6 139
12Wärmepumpe für Neubau-Einfamilienhaus Effizienzhaus 55 12
13Luftwärmepumpe oder Gas und Solar nutzen? 300
14Dimensionierung der Heizung ausreichend? 15
15Gas und Solarthermie - Fragen zum Angebot 28
16Photovoltaik für Warmwasser 26
17Warmwasser nur mit Wärmepumpe? 10
18Solar für Warmwasser/Heizung oder besser Photovoltaik für Strom? 21
19In der Dusche kommt kein Warmwasser mehr an... 13
20Solarthermie und Pelletheizung, Heizungsunterstützung/Warmwasser 16
